Starry Posted June 27, 2008 Report Share Posted June 27, 2008 Not heating up at home. It has the heater that looks like a trombone I hit the reset switch about an hour and a half ago.. and still nothing.. All the jets work and the ozonator is working.. just no heat.. any advice? Quote Link to comment Share on other sites More sharing options...
Hillbilly Hot Tub Posted June 28, 2008 Report Share Posted June 28, 2008 Not heating up at home. It has the heater that looks like a trombone I hit the reset switch about an hour and a half ago.. and still nothing.. All the jets work and the ozonator is working.. just no heat.. any advice? Is the power hooked up properly? Is it 110 or 220? Running of an extension cord? Quote Link to comment Share on other sites More sharing options...
Starry Posted June 29, 2008 Author Report Share Posted June 29, 2008 Not heating up at home. It has the heater that looks like a trombone I hit the reset switch about an hour and a half ago.. and still nothing.. All the jets work and the ozonator is working.. just no heat.. any advice? Is the power hooked up properly? Is it 110 or 220? Running of an extension cord? Yeah the power is hooked up 220.. no extension cord.. it has a sub panel and all that jazz. Everything works.. the jets turn on.. the ozonator is bubbling.. just no heat.. The lights all are lit inside the electric panel.. heater and the other 2. I have no idea.. and my local spa place wants $150 just to come look at it and they said it they have to replace the heater its $350 for the part alone and $95 an hour for labor.. It seems like a major rip off to me.. someone help!! Thanks!! Quote Link to comment Share on other sites More sharing options...
rusty-D Posted July 1, 2008 Report Share Posted July 1, 2008 do you have any error in your control??? Flo 1 - 2 flashing lighsts,, something????? sometimes even dirty filter will create that probelm. Quote Link to comment Share on other sites More sharing options...
Dan.The.Spa.Man Posted July 2, 2008 Report Share Posted July 2, 2008 You need to see if there is voltage at the heater relay. If you have a meter check to see if there is 220 volts coming through the relay. Also, if you hit it an hour and a half ago the tub may only heat up 4-8 degrees or so in that time and you may not realize a big difference yet. Quote Link to comment Share on other sites More sharing options...
