wineo Posted May 26, 2008 Report Share Posted May 26, 2008 I have recently bought a hot tub and notice that my daughter breaks out in a rash. The chlorine and both bromine irrate her skin. The hot tub is balanced and water tested. I have heard that hydrogen peroide works. It is a natural product and does not irritate the skin and is not harmful. This is the only product needed in the hot tub and is used to clean filter as well. Does anyone use this in their hot tub and if so what is the pros and cons to this. Quote Link to comment Share on other sites More sharing options...
ps558 Posted May 26, 2008 Report Share Posted May 26, 2008 I have recently bought a hot tub and notice that my daughter breaks out in a rash. The chlorine and both bromine irrate her skin. The hot tub is balanced and water tested. I have heard that hydrogen peroide works. It is a natural product and does not irritate the skin and is not harmful. This is the only product needed in the hot tub and is used to clean filter as well. Does anyone use this in their hot tub and if so what is the pros and cons to this. If you want get away from the bromine and chlorine find a dealer that sells Soft Soak or Baqua Spa. Quote Link to comment Share on other sites More sharing options...
tubtechie Posted May 26, 2008 Report Share Posted May 26, 2008 I have recently bought a hot tub and notice that my daughter breaks out in a rash. The chlorine and both bromine irrate her skin. The hot tub is balanced and water tested. I have heard that hydrogen peroide works. It is a natural product and does not irritate the skin and is not harmful. This is the only product needed in the hot tub and is used to clean filter as well. Does anyone use this in their hot tub and if so what is the pros and cons to this. For my 2 cents worth, I recommend the nature2 products. Nothing out there will totally get you away from chemicals but can greatly reduce the amount enough even for those with sensative skin. Quote Link to comment Share on other sites More sharing options...
