DJ TonyT Posted March 19, 2008 Report Share Posted March 19, 2008 Hi there....I am new so please be patient with me. I have an old in ground pool built about 1969...the pool is in really good shape to be the age it is. I want to add a cleaner now that the kids a grown, no one really wants to keep it clean. I have been looking the Polaris 360 which is the model that works off of the return without a booster pump. My pool has three returns. Each return is kinda small I guess they all three are 1/2 inch inside the hole. From what I can tell looking at the Polaris website I need a return that is at least 1 inch inside the hole or pipe. Can someone help me understand how I can make this work or is it impossible and I should be looking at a different cleaner. Thanks for your time and I look forward to some advice...... Quote Link to comment Share on other sites More sharing options...
drip Posted March 21, 2008 Report Share Posted March 21, 2008 The 360 would not be a good idea, it would probably not work very well on a 1/2 inch line and they need all the help they can get anyway. My recommendation would be a "robotic" cleaner, it just plugs into 110 gets dropped down to 24 volts at the control box for it and most of them do a really good job of cleaning the pool. I've only had experience with the Dolphin and it works very good. Quote Link to comment Share on other sites More sharing options...
muss51 Posted March 21, 2008 Report Share Posted March 21, 2008 I would personally recommend a polaris 380 or 180. Both are great but require a booster pump. I have nothing against robots but I have found that repairing them can be costly. Also, this is only a personal preference, I dont want anything in my pool that plugs into a wall. Makes me nervous. Quote Link to comment Share on other sites More sharing options...
Discountpoolspa Posted March 22, 2008 Report Share Posted March 22, 2008 Any return side cleaner will require a single, dedicated return line in the pool. They are not going to work properly if they are sharing water flow with other pool returns. The polaris 360 does not require a booster pump, and works well, but it will still need a dedicated line coming from the equipment. The 280 and 380 work excellent, but will need that dedicated line plus a booster pump at the equipment. If you don't have large debris, such as large leaves, a suction side cleaner could be connected to the skimmer, or to a dedicated suction line (if there is one). Otherwise, without major work, the robotic cleaner will be your best option, as it doesn't require any plumbing at all. Quote Link to comment Share on other sites More sharing options...
