chanster Posted December 14, 2007 Report Share Posted December 14, 2007 i just took delivery of a new marquis 641r (thanks to all of you who contributed to my earlier thread). the marquis dealer's only lifter required 20+ inches of rear clearance. my installation has the tub in a corner, facing my pool, with walls on two sides. due to the proximity of the house to the pool, i have to place the spa fairly close to the wall...about 12 inches. so i need a cover lifter that will use no more than 12 inches. it appears that all of the low-clearance lifters store the cover above and slightly behind the spa, not stored down behind it (which is fine). what brands/options are the best? any links to good dealers? thanks for all your help. Quote Link to comment Share on other sites More sharing options...
Pathfinder Posted December 14, 2007 Report Share Posted December 14, 2007 Covermate 3 from Leisure Concepts is the best for confined space IMO. Although the cover sit fully above the tub. Quote Link to comment Share on other sites More sharing options...
chanster Posted December 15, 2007 Author Report Share Posted December 15, 2007 Covermate 3 from Leisure Concepts is the best for confined space IMO. Although the cover sit fully above the tub. pathfinder, it appears that the covermate 3 attaches to the side of the spa, just below the fiberglass, with 10 screws. in my installation, the cover needs to lift to the left of the access panel (ie facing the access, the cover would fold to the left, not the rear), which means that the mount on that side would also screw the access panel into place...i would have to remove all those screws to get to the guts of the spa. that is doable, but i would rather avoid it. might there be another type of zero clearance lifter that would mount to the bottom of the spa and not restrict access to the panel? thanks chan Quote Link to comment Share on other sites More sharing options...
Solomon Posted December 15, 2007 Report Share Posted December 15, 2007 Have you checked out a Cover Valet? http://www.covervalet.com/products/coverlifters/ Quote Link to comment Share on other sites More sharing options...
Pathfinder Posted December 15, 2007 Report Share Posted December 15, 2007 its a copy of the covermate 3 Quote Link to comment Share on other sites More sharing options...
Shaamus Posted December 17, 2007 Report Share Posted December 17, 2007 its a copy of the covermate 3 Technically, if you follow the patent royalties being paid, the Covermate 3 is a copy of the Cover Valet. Don't get me wrong, they are different lifts but the Valet came first and has the patent. Quote Link to comment Share on other sites More sharing options...
