Depending on your climate, I'd want that spa filled, running, and heated before I bought it. Even if they offer to write a contract to fix it, you'd still potentially be moving a spa to your house and setting it up, wiring it, filling it... only to find out they didn't winterize it and have a leak. When buying privately, I prefer to see the spa in operation to make sure it heats, runs, and their patio isn't wet from any leaks.
Price wise though, that sounds like a pretty good deal. The Hot Spring Vista is a great spa, and honestly it sells for more than double that in my market brand new.
As far as the concrete pad is concerned. Hot Spring actually recommends a 4" reinforced concrete pad for that spa. See page 4 of the following document:
2007 Hot Spring Pre-Delivery Instructions (Foundation, Dimensions, & electrical wiring)
http://www.hotspring.com/pdfs/pre_delivery...ctions_2007.pdf
You can find the 2007 Hot Spring Owner's Manual here:
http://www.hotspring.com/Hot_Tub_Customers...e-delivery.html
Just talked to the owner and he's having his spa dealer come out and inspect the tub to make sure everything works and create a report.
One other thing you might want to ask is if the tub has ever sat dry for a long period of time..This can cause o-rings to dry and crack as well as glue joints to fail....Have a huge problem with that her in the west...Hot summers cold winters...Mike
