paxthar Posted February 5, 2010 Report Posted February 5, 2010 Just wondering what I can use to clean the inside of my tub, it had what looked like black spots of ??mold, which come off easily when wiped with your finger. But I want to give the tub a good cleaning and polishing on the inside. And what can I use to run through the tub so as to hopefully wipe out any contaminants in the lines? Is there a step by step guide for a newbie like me for a hot tub clean out and setup? Thanks in advance. Quote
NewB@Spa Posted February 5, 2010 Report Posted February 5, 2010 Nitro has an excellent explanation for decontamination - this may not be your case, but a once a year decon never hurts. http://www.poolspaforum.com/forum/index.ph...c=19115&hl= Also in Nitro's topic you will find an excellent method for water maintenance - easier and cheaper than Dichlor/Trichlor alone Quote
topmahof Posted February 15, 2010 Report Posted February 15, 2010 running spa flush through your tub right before draining cleans out contaminants fairly well. if your tub has a smooth acrilic finish you can use a good quality car wax on it once a year. it'll make it shine again. Quote
NewB@Spa Posted February 15, 2010 Report Posted February 15, 2010 Gel Gloss is a good product to use in shining your tub. I use it also on my interior shower walls it helps to reduce spotting and makes it easier to wipe. Quote
