JohnP Posted January 23, 2010 Report Posted January 23, 2010 I have low pressure coming out of my Sta-Rite heater I think. The filter is clean and pressure is good on the filter. The water is still going into the hot tub and heating, but just not enough water pressure is going through. Could it be cracked heater coils or could a bad manifold bypass valve cause this. I am also not loosing any water, so I don't think it is cracked pipes underground. Thanks in advance Quote
Pool Clown Posted January 24, 2010 Report Posted January 24, 2010 I have low pressure coming out of my Sta-Rite heater I think. What makes you think this? What is happening? The filter is clean and pressure is good on the filter. What is the pressure? The water is still going into the hot tub and heating, but just not enough water pressure is going through. Did it used to heat faster? Could it be cracked heater coils You would be able to tell cuz you would have a good leak at the heater. Quote
