I came home today, my Aqualink RS6 says pump is off but when I went outside my main pump is running! I checked the power panel it was still in Auto mode. If I select Service mode, the pump remains on. When I select Time Out Mode the pump remains on but the light flashes. I tried resetting the system at the power panel (outside) nothing changed. The only way I can turn my pump off is by turning off the breaker switch on the power panel.
Please Help
Thanks
Sounds like a stuck relay. You can shut the pump off at the breaker, and go to the local pool store and get a Jandy relay. If your'e not comfortable changing that relay, You should call and have a professional take care of it for you.
Pool Clown to the rescue again. If you worked in S. Texas I'd hire you all day.
Thank you
