In the pre-delivery instructions on the Vista wiring diagram, there's a heater ground (looks like a spade connection) indicated inside the cabinet but it doesn't specify any wire termination to that ground. What am I supposed to do with that heater ground connection indicated on the wiring diagram (if anything)? Thanks
Nothing. It is connected for you the the grounding bar were you install the ground from your breaker panel
Thanks. I don't have the tub yet to see what's going on. Just trying to have everything ready when I pick it up.
