dwe Posted October 25, 2009 Report Posted October 25, 2009 I have a 2hp Whisperflo pump that started shutting down for about 20 - 30 seconds. It did this a couple of times within 20 mins. I went to the pump and it felt hot so I shut it down last night. This morning it was doing it again so I have shut it down again. Any suggestions??? Thanks Quote
Pool Clown Posted October 26, 2009 Report Posted October 26, 2009 Sounds like you need a new motor. Quote
dwe Posted October 26, 2009 Author Report Posted October 26, 2009 Sounds like you need a new motor. I called the company this morning and they are sending someone out. I would think warranty should cover it since the pool was installed in June. Thanks Quote
Pool Clown Posted October 27, 2009 Report Posted October 27, 2009 I would think warranty should cover it since the pool was installed in June. As long as the failure is not due to a leaking shaft seal. They won't warranty those. Has the pump had a small leak, coming from underneath ? Quote
