Hello All, my Jandy terminal display " general fault check aquapure " and also shows salt as 25500 PPM , it was 2200 PPM before I got this strange number. I had to go to pool equepment and unscrew two screws to access aquapure board where it shows colorine producing 70% then after a while it displays 172 then 185 then goes back to 70% . the cells seems pretty clean. thanks for any hints
You need to check the tri-sensor (Temperature, salinity and flow).
6.5 Flow/Temp/Salinity Sensor Cleaning
One time per year or as needed. It is rare but scale formations on the Flow/Temp/Salinity Sensor sometimes
occur and will affect the accuracy of the salinity test.
1. Remove Flow/Temp/Salinity Sensor from the threaded PVC Tee or 3-Port Cell by turning
counterclockwise or removing the union nut.
2. Brush with a mildly abrasive green fiber household cleaning pad. Contacts should be clean and bright.
3. Thoroughly rinse the Flow/Temp/Salinity Sensor with clean tap water. Replace and resume normal
operation.
4. Turn power off and back on in order to recalibrate and reset Flow/Temp/Salinity Sensor. Reset
anytime Flow/Temp/Salinity Sensor is unplugged.
http://www.jandy-downloads.com/pdfs/AquaPure_Manual.pdf
Is the temperature reading accurate?
Hello quantumchromodynamics
Thanks for your reply but I'm having a hard time locating the Flow/Temp/Salinity Sensor , my system is APURE700 , the assemply looks like figure 19 in page 39 of http://www.jandy-downloads.com/pdfs/AquaPure_Manual.pdf and yes the temperature reading is accurate for both air and pool temp
can you please guide me where can I find the Flow/Temp/Salinity Sensor
Is the temperature reading accurate? yes for both pool water and air
Thank you Pool Clown, I located the sensor , it was hiddin facing downward on pvc pipe, I took it out and cleaned the three small silver sensor buds and plugged it back, recycled power but nothing change , still reads "SALT 25500 PPM General Fault, check aquapure " message.
does this mean sensor is gone or there is something else that could be checked?
