I have a polaris booster pump that I am going to replace. I bought a used one that was running off 110 I think....it has a regular wall plug. The old one was running off 220. Are all those pumps able to run off 220? Can i just connect the two hot leads?
Also, do I have to use the hayward super reinforced 6' hose to run to the pump? or can I just buy some flex hose from Lowe's
Thanks
There is, (or should be) a service plate on the side of the motor. It should have a wiring diagram to switch it over to 220V. Likely two wires must be switched. Use the Hayward hoses if you can, It may be more pliable to get it on to the barb fitting than the Lowes hose.
