sassygirl Posted October 17, 2007 Report Share Posted October 17, 2007 Hi can someone tell me different between shock and chlorine why do I use one instead of other? Does shock disipate chlorine in water? why use both? D1 Lotus bay with vision cartridge sassy girl Quote Link to comment Share on other sites More sharing options...
tony Posted October 17, 2007 Report Share Posted October 17, 2007 Hi can someone tell me different between shock and chlorine why do I use one instead of other? Does shock disipate chlorine in water? why use both? D1 Lotus bay with vision cartridge sassy girl Shocking a spa can be accomplished in two ways...the addition of MPS aka non chlorine shock which is a powerful oxidizer or by reaching what is called breakpoint chlorination through the addition of chlorine to raise the free chlorine level to ten times the combined chlorine level. Shocking eliminates organics, etc left in the water by the sanitizer. To simplify, you should shock your water at least weekly with either the proper amount of non chlorine shock or between five and ten ppm chlorine. Now the difference between chlorine and non chlorine shock is chlorine is a sanitizer and oxidizer while non chlorine shock only oxidizes...it has no sanitizing ability. You need a sanitizer to kill bacteria, etc and keep your water safe. Shocking or oxidizing burns up what is left behind to clear your water. Non chlorine shock does not disipate chlorine in water, it should do the opposite..allow your free chlorine level to last longer. My routine is I sanitize as needed (when used) and shock with non chlorine shock weekly. If my water gets into trouble I add a shock dose of chlorine to get it clear. Quote Link to comment Share on other sites More sharing options...
