Kent Ohio Posted October 11, 2007 Report Share Posted October 11, 2007 Anyone know good site, with pictures, how to mount the disconnect to the house with a weatherproof seal?? New Tub arrives tomorrow(Friday) WOOO HOOO!!!!! Quote Link to comment Share on other sites More sharing options...
TinyBubbles Posted October 11, 2007 Report Share Posted October 11, 2007 Is mounting to your house the only option? Could you mount it on a post? Quote Link to comment Share on other sites More sharing options...
Kent Ohio Posted October 11, 2007 Author Report Share Posted October 11, 2007 hmmmm, well, I assumed I would mount it to the house, that was the most obvious(to me) location. There are 3 posts holding the deck above up, 2 of the 3 are definatly too close, less than 5 feet, the 3rd might be far enough away, but I'd have to go back and get more wiring for the longer run out there, pricey at near $3/foot. But, yeah, it is more than likely going on the house. Quote Link to comment Share on other sites More sharing options...
dave nh Posted October 11, 2007 Report Share Posted October 11, 2007 Here is a pic of mine attached to the house if it helps. There is an eave/gutter on second story above which keeps most of the direct weather out. The box is obviously outdoor rated. Mounting screws were sealed and i used electricians putty, The kind they put on meters outside to seal wire penetration through sill. Congrats on the new tub! House Mounted GFCI Disconnect Quote Link to comment Share on other sites More sharing options...
Kent Ohio Posted October 11, 2007 Author Report Share Posted October 11, 2007 Here is a pic of mine attached to the house if it helps. There is an eave/gutter on second story above which keeps most of the direct weather out. The box is obviously outdoor rated. Mounting screws were sealed and i used electricians putty, The kind they put on meters outside to seal wire penetration through sill. Congrats on the new tub! House Mounted GFCI Disconnect You just used putty behind the box where the wires come from inside the house through to the box?? Quote Link to comment Share on other sites More sharing options...
dave nh Posted October 11, 2007 Report Share Posted October 11, 2007 Yes, sepco duct seal weatherproof compund along with a halex clamp in the box. The penetration through the house is only about 1" in diameter. Seems to do the job. Quote Link to comment Share on other sites More sharing options...
Stuart A Posted October 18, 2007 Report Share Posted October 18, 2007 Or you could run a fine bead of clear silicone around the outside back edge. Quote Link to comment Share on other sites More sharing options...
