jelly52 Posted September 20, 2007 Report Share Posted September 20, 2007 I recently bought a used spa. My first. How do I set the thermostat for the heater? Does spa have to run continuously in order to keep the heat going? When I turn spa on the heater light comes on, which is fine, it heats up great, but when I turn spa off the heater goes off. I thought heater would stay on so spa would be heated every time I get in. Is this an older model? I have no paper work, Spa has no name. helppppp Quote Link to comment Share on other sites More sharing options...
cplarsen Posted September 20, 2007 Report Share Posted September 20, 2007 Spa has no name but the equipment inside does. Open it up and let us know what you have. Btw, if its at the right temp when you shut it off, the heater is not going to run. Does it cycle back on later as it cools? Quote Link to comment Share on other sites More sharing options...
