Pool Amateur Posted September 16, 2007 Report Share Posted September 16, 2007 OK, quick Jandy Aqualink Question... I have an RS8 control pad in the house, and a Spa Side 4 button remote. Over the past month, the spa air blower has been turning on by itself, I had a feeling that the 4 button remote on the spa was responsible (becuase it was cracked), so I replaced it and wired in to the power center correctly (I checked this thoroughly). However, over the past few days, the entire system becomes intermittently unresponsive, the spa and heater will turn on on their own, the waterfall will turn on whenever I hit the heater button, I can't move into service mode at the main power center to turn things off, things are just acting crazy... However, if I go to the power center and disconnect the main board from power (by disconnecting the orange and green wire plug) and leave it off for a time (say 2 hours) and then reconnect the main board, everything work fine for a while...but they eventually fritz out again... My pool guys says I need a new main board at the power center ($1,800!!!!!!) but I'm skeptical, I'm thinking it's a faulty relay, and not the main board... Any thoughts out there? Should I try replacing all the relays before springing for a new board? Any other troubleshooting tips? Quote Link to comment Share on other sites More sharing options...
Pathfinder Posted September 16, 2007 Report Share Posted September 16, 2007 Call Jandy direct and talk to someone in tech. The aqualinks dont down all the time so your pool guy probably hasnt had much experience trouble shooting. Quote Link to comment Share on other sites More sharing options...
Pool Amateur Posted September 18, 2007 Author Report Share Posted September 18, 2007 Call Jandy direct and talk to someone in tech. The aqualinks dont down all the time so your pool guy probably hasnt had much experience trouble shooting. I just noticed that I'm getting a "Water Sensor Shorted" on the RS8...that's new... Quote Link to comment Share on other sites More sharing options...
advanced pool design Posted September 28, 2007 Report Share Posted September 28, 2007 A relay is used for each function, so Its unlikely that its a relay. From what you have said, I would tend to agree that the main board is gone. There might be a 20 cent part on that board that is heating up, (you said unplugging it for a while and it starts working for a bit), but you wont find it yourself. You didn't say how old it was but anyway that price sounds a bit high. I would guess it would be guaranteed by the pool company and if it didnt fix the problem you would not pay, right? Good luck.. Quote Link to comment Share on other sites More sharing options...
