Nikki Posted June 10, 2007 Report Share Posted June 10, 2007 I've read that you can add salt (solar salt) to a pool even when you're using the BBB method. Wondering how many of you have tried it and if you've noticed a difference in the feel of the water. I am going to give it a try, but am having a hard time figuring out how much salt to add. I also need to order a test kit that tests the CYA. I looked at Walmart, Target and Lowes today, but none of the kits test the CYA levels. Quote Link to comment Share on other sites More sharing options...
jenlind Posted June 10, 2007 Report Share Posted June 10, 2007 Hi Nikki. Fancy seeing you here. I picked up a kit at Walmart and it does test for CYA. It is called the HTH 6 Way kit, and it cost around $15. Quote Link to comment Share on other sites More sharing options...
Nikki Posted June 10, 2007 Author Report Share Posted June 10, 2007 Cool...thanks! I went today and they were out of EVERY SINGLE testing kit. I will check a different Walmart and see if they have one. Quote Link to comment Share on other sites More sharing options...
