GrammaG Posted July 19, 2023 Report Share Posted July 19, 2023 I need a recommendation cover lifter for 8 x 15 master spa H2X . I’m almost 70 and not too strong. Quote Link to comment Share on other sites More sharing options...
cranbiz Posted July 20, 2023 Report Share Posted July 20, 2023 Many use The Cover Guys. Quote Link to comment Share on other sites More sharing options...
CrazyDogLady Posted August 10, 2023 Report Share Posted August 10, 2023 You might look into the Smartop. The cover includes a dual cover lift system that helps with the weight of the cover when opening and closing - both the front and back half of the cover. It is a hardcover with non-water absorbing interior insulating foam so it won't become water-logged and heavier over time. It is a bit more expensive than a regular vinyl cover however, you shouldn't have to replace your cover every few years like you do with a traditional cover, and it includes the dual cover lift system. Quote Link to comment Share on other sites More sharing options...
