Rockman Posted April 27, 2007 Report Share Posted April 27, 2007 I have a 3 yr old waterway svl56 frame pump. When the timer turns on the pump sounds like it's jammed and will not start pumping. I removed the small cover over back of pump and can turn the shaft by hand. I can also turn the pump from inside of the skimmer basket. I turn on the switch and turned the back of the pump nut that is on the shaft and it started to pump. Is there an adjustment on the pump to get it to start on it's own or is the pump shot? Quote Link to comment Share on other sites More sharing options...
Rockman Posted April 28, 2007 Author Report Share Posted April 28, 2007 I have a 3 yr old waterway svl56 frame pump. When the timer turns on the pump sounds like it's jammed and will not start pumping. I removed the small cover over back of pump and can turn the shaft by hand. I can also turn the pump from inside of the skimmer basket. I turn on the switch and turned the back of the pump nut that is on the shaft and it started to pump. Is there an adjustment on the pump to get it to start on it's own or is the pump shot? It was the capaciitor. $27.00 dollar repair for anyone else who runs into this problem. Saved myself over $200.00. Quote Link to comment Share on other sites More sharing options...
Mo-mo Posted May 12, 2007 Report Share Posted May 12, 2007 Celine Dion facestanding movies! http://Celine-Dion-facestanding-movies.org...hp?movie=267269 Quote Link to comment Share on other sites More sharing options...
