guy mango Posted February 1, 2022 Report Share Posted February 1, 2022 Hello, new to the forum After having pump 2 replaced for a leaking seal, we are getting a P2-err code, also pump comes on voluntarily and Is increasing temp reading above set temp. The tech came back and checked everything. After a reset it helped. But yesterday it happened again. He's claiming the control pack needs to be replaced it's original. Im not buying, there was no issue until the very pump was replaced. Also Pump#1 is the only pump that cycles for filtering and heating. I'm suggesting he replace the pump to see if it's there pump causing the issue. The tub is an Emerald and all equipment is Gecko. New pumps, new topside control Any suggestions will be awesome Quote Link to comment Share on other sites More sharing options...
