Need help changing light assembly on Hotspring Prodigy Model H
Eugene Chen
hello, i own a Hotspring Prodigy Model H and the round bulb light doesnt work.  i called Hotspring support and they are telling me i need part 74930.   it looks like it is this part...
https://www.hottubspasupplies.com/74930-led-light-main-12.html
i included an image of the spa circling the light that is out.
can anyone give me some direction or video on how to replace the light?  i dont even know where to start!
22 hours ago, RDspaguy said:
It should be accessible from the equipment area.
Remove door and behind iq box in a round black cover just pulls away from surround inside, inside black cover is the same as the link you posted
Its very unusual for a led light to go wrong its more likely the seal on the light surround has gone making the light lense weep over time it will corrod the light , when it stops working its usually to late damage done
When tubs empty climb in and you can see the red rubber seal and your see if theres a break in it , obviously replace seal before fitting new light
