greenhut Posted November 22, 2005 Report Share Posted November 22, 2005 First I would like to thank all those that made such informative posts that helped us along in our decision. Posts by Chas, spatech, and East TX Spa were particularly helpful! I must even say that after applying a good dose of "filter" (100% filtration of course), there was even some good info in Jims posts I really enjoyed Jim's fictional depiction of the Hot Spring CEO, engineer, and marketing exec. Hopefully I can add some info that will help others in their decision. Our Spa History My family lives in the Atlanta area and has owned a Sundance Marin for 10 years. The dealer (while they were still a Sundance dealer) was never particularly good about service, and our Marin needed quite a bit of it. They have since moved on to another line, and Sundance has been picked up by a large outdoor store chain. For the last four months, we have been unable to get our Marin repaired (leaks and an electrical issue). We have thrown in the towel – it will be lugged off as junk when our new tub is delivered. If anyone is interested in key spares (jet pumps, heater, control board, lcd, circ pump) for a Sundance Marin, drop me a note. After struggling with the Marin and the dealer situation, we refused to consider another Sundance product. We enjoyed ours, and from what I read, Sundance remains competitive with the other premium brands. For Consideration We considered Caldera, Hot Spring, Tiger River, Marquis, D1, and Coleman. We wet tested a HS Envoy and Caldera Geneva, and dry tested a Tiger Rivers Caspian. The Geneva and Envoy were our two leading contenders after reviewing web sites, specs, forums, and dealer proximity. The Coleman, D1, and Marquis are ~45 minute drives for us. The HS and Caldera dealers are ~15 minutes away and both have been in business for a very long time (although the Caldera dealer has only carried Caldera for 3 years). Coleman: My sense based only from web sites and forums is that Coleman is not quite in the same class as the other brands mentioned - this of course may be wrong. The feature that most interested me in the Coleman is the non-full foamed insulation approach. After experiencing numerous leaks with out Sundance, I can say that insulation approach used by Coleman and it’s associated ease of service is very interesting. BTW, we would have loved to consider Arctic, but no dealer in the state. Dimesion1: The Lotus appears to be a beautiful, powerful, and full featured spa. We would probably not choose it though due to cost and somewhat smaller size than we want. The Chairman II would be the model we'd look at. Marquis: Why does the dealer have to be so far away? These spas (again on paper), have some features that really spoke to me. At the top of the list is the warranty - 7 Year Leak Warranty and the entire warranty is transferable. All other brands we considered are 5 year component/leak and non-transferable. The textured acrylic base was also nice - I just don't like the idea of wet wood sitting outside on concrete. Due to the distance from the Coleman, D1, and Marquis dealers, and the fact we found a tub we really liked, we did not go any further with these brands beyond web research. One of these tubs may have been a good choice for us, but you have to draw the line on time put into the decision somewhere... Wet Test - Hot Spring Envoy Our first wet test was with the HS Envoy. Spas Atlanta has it setup in a nice area where a partition can be closed for complete privacy. Overall nice experience - we enjoyed the Envoy. Amazingly, when gathering our thoughts, we found two of the same issues that had surfaced 10 years ago when we evaluated a HS Sovereign. We found the power lacking (and this is considered a High Power HS model). Since these are such popular tubs, I can only conclude my wife and I like stronger jets than most. My thought is that the combination of slightly lower powered pumps, and the extra work they have to do to pull all water through the filters leads to the somewhat weaker jets in HS Spas. On the other hand, I see real value in 100% filtration. It is likely to payback in reliability by never allowing unfiltered water to enter the “system”. Being able to clean the TriX filters in a dishwasher is a nice as well. We found the diverter scheme confusing. There are two diverters, and they are not simple 180 degrees left/right travel. They move a full 360 degrees. The salesperson indicated each valve had 4 different positions (I don't know if this is correct). We could find no way to simultaneously activate the two rotary jets (which we liked) and the foot jets in front of it. The real issue though was the lack of intuitive settings of the valves to drive the various jets. The Envoy is a relatively deep tub and sits deep. As such, it does not work well with small kids. It also offers no seats that are much out of the water. Best bet here is sitting on the knee area of the lounger which isn’t exactly comfortable. Hotspring really needs to bring the full control panel into the tub. The main control panel is outside the tub, halfway down the front of the spa and impossible to see from in the tub unless you really hang out. You can't see the temp in the tub or adjust it (without of course reaching out). With the main controls out of site, you are left with the in tub mini control panel. It has no display, offers few functions, and is awkward. For example, there is only one jets button which has to be pushed 6 times to cycle through all jet option. 1st push is pump 2 low, then pump 2 hi, then pump 1 hi + pump 2 hi, pump 1 hi and 2 low, then just pump 1 hi, then off. Couldn't they have added 1 more button for independent pump 1/2 control? Two of the four buttons on the in-tub control panel are for SpaAudio, which based on its ~1500 price, I imagine is a relatively rare option. The MotoMassage was very nice. There are lots of gimmicky jets out there, but this is truly unique and effective. We found though that the MM only moved well if it had full power from the diverter. The Bellafontana three stream fountain was good fun for the kids. After wet testing the Envoy we walked the HS floor looking for a different tub that might address our issues. The Tiger River Caspian was the only other possibility. The sales person indicated its jets are more powerful than any HS tub (IMO due to bypass filtration). It has no diverters, and offers good out of water seating options. The central circular foot jets, accessible from any seat also looked good. It was difficult to say based only on a dry test, but we feared it might be too small a tub for us; particularly all feet overlapping in the middle. Given the price, we still feel the Caspian to be one of the best values available. (continued) (part II) Wet Test – Caldera Geneva We visited Recreation Warehouse to view and wet test Caldera. Our salesman Gary was by far the most knowledgeable about his and his competitors’ products. Although we were very educated on the Calderas before entering the store, we learned a lot from Gary and appreciated his general sales approach. Unfortunately, the Geneva we tested was sitting right by the entrance to the store. After overcoming our modesty, we got on with the wet test. Before even entering the tub, we were sensing that this could be “the one”. The first thing we noticed was the power of the jets. The Caldera has three diverter valves, but unlike the HS, they are 2 positional and very easy to understand. With all the jets in the tub on (diverters in the middle), the power of the jets felt similar to the Envoy with full power directed to one seat. Setting the diverters in the Geneva to concentrate power to a seat delivered anywhere from outstanding to frightening jet power (Chas E-ticket). The depth was a much better fit for us (BTW I am 6’ 2” and my wife 5’ 7”), and there was at least one seat that got us up out of the water enough to cool down and provide good toddler space. We also found that the contour of the seats kept us in the seat better than the Envoy or our old Sundance. There are three seats in the Geneva that offer “Best seat in the tub” experience, and they are all different. My favorite was the lounge – in addition to a great back massage, the 10 powerful foot jets were awesome. Stock, these jets are small aimable nozzles, but they can be replaced with the Europulse jets found in the wrist area of the Ecstaseat. My wife’s favorite seat was the Ecstaseat – she loved the wrist jets and used them for a hand massage. I found that I was not able to get the wrist jets onto my fingers without pulling my elbows back uncomfortably. We both found the Neck Jet pillow in the Ecstaseat a disappointment. It sounded great on paper, but with the Ecstaseat blasting away, I could barely tell if the above water neck jets were even turned on via their independent control. It is nice thought that you can activate only the neck jets and not the rest of the Ecstaseat. My second favorite seat was the LumbarSage seat. It did a great job of getting to the lower back. While in the LumbarSage, you can rest your left foot on the giant whirlpool jet, and the right foot on the giant Euphoria jet. Through the diverters, it is possible to send all 2.5 horsepower to the whirlpool or Euporia jet – even splitting the 2.5 HP across both of the jets results in super powered jets. The nozzle on the Euphoria and Whirpool jets can be “pushed in”. I think this is supposed to dampen the flow. It was extremely difficult to pull the nozzle back out. Overall, we were surprised by the quality, diversity and comfort of the massages offered in the Geneva. The Geneva felt like a big upgrade over our Sundance, the Envoy did not. The Geneva includes a single speed air jet system with 10 air ports. While I sometimes enjoyed using the air in our old Sundance, my wife hated it because it caused water to splash up in her eyes. During the wet test, I managed to keep it on for about 6 seconds before she popped the air button. It does provide a nice alternative feel vs direct jet pressure. The Geneva includes LED lighting on three exterior sides of the tub, the interior, the hand rail, and the filter area/waterfall. BTW, the waterfall seems like a bit of a hack as it utilizes the filter basket lid. This makes replacing the lid a bit tricky as you must lineup the supply tube and fiber optic transfer tube. We preferred the HS Bellafontana water feature as its position in the tub allowed the kids to swim under the arching water like a bridge. The lighting can be programmed to come on at the same time each evening. This is a great feature for us as it allows for a visible path to the tub without turning on our bright and annoying regular outdoor lights. Since they are LEDs, I imagine the cost is not even noticeable. The Geneva’s controls far surpassed the Envoys. First, the main control panel is “in” the tub. All functions can be accessed in the tub, and the screen is easily read in the tub (you can even invert the temp display). A secondary control panel is located on the opposite side of the tub and has individual Jets 1 and 2 buttons, lights, and a mode control button for stereo use. The mechanical controls on the Geneva also surpassed the Envoy. Aside from their ease of use, the diverters moved much more smoothly and were quiet. Even the air intake switches had a smooth and solid feel. We would have liked foot jets when sitting in the Ecstaseat – there are none. However the foot jets in the lounge are amazing; as are the Euphoria and Whirlpool as foot jets. Since I have varicose veins in my leg, the calf jets in the Ecstaseat are a “no-no”. They can be avoided, but not disabled. We also would have liked a slightly higher cool off seat. Costs Envoy: We were quoted $8300 + tax (including Ozone, cover-mate lifter, stairs, cover, Delivery, chemical start up). My sense is I may have been able to knock another $300 with some persistence. Geneva: We were quoted $8200 + tax (including GFCI panel, Ozone, cover-mate lifter, stairs, cover, Delivery, chemical start up). At this price they were not willing to do the 13 month no interest/same as cash promotion. The dealer also agreed to remove our Sundance for $100 – I think the dealer probably put about $100 towards this to the install company. Conclusion We bought the Geneva. Even sitting half naked in the middle of a retail store, we strongly preferred the Geneva over the Envoy. Depth, pump power, jets, and controls were all big factors in the wet test. The overall quality of the tubs felt very similar, however given the extra bells and whistles on the Geneva, and the maturity of the HS product, I expect the Geneva to have more service issues over its life. Providing that my “No but I stayed in a Holiday Inn Express last night” electrical expertise is adequate, we’ll be in the tub this evening (it is scheduled for delivery in about 1 hour ) Recommendations I’m sure you have read it before, but you MUST wet test a spa before buying. It would be like purchasing a car without a test drive. On paper the Envoy and Geneva (and many other brands) are very similar. For my family, the wet test experience was anything but similar. I hope this can help someone else in making their decision. jeff Quote Link to comment Share on other sites More sharing options...
spatech (the unreal one) Posted November 22, 2005 Report Share Posted November 22, 2005 First I would like to thank all those that made such informative posts that helped us along in our decision. Thank yourself for taking the time to find the spa that is right for you. Congrats. Quote Link to comment Share on other sites More sharing options...
East TX Spa Posted November 22, 2005 Report Share Posted November 22, 2005 greenhut, what an outstanding post! Although it saddens me that the Envoy wasn't for you (it's my personal favorite), you went about the process the right way and found the spa that was best for YOU and YOUR FAMILY. We can all sit on this forum and debate this and that 'til the cows come home, but you did the research yourself, you compared, you wet tested, and you found your spa. Congratulations and I hope you enjoy your spa trouble free for years to come. You picked a good one! Terminator Quote Link to comment Share on other sites More sharing options...
greenhut Posted November 23, 2005 Author Report Share Posted November 23, 2005 The tub was installed today. It did not exactly go smoothly, but it is in. 92 degrees and counting... Quote Link to comment Share on other sites More sharing options...
cancel99 Posted November 23, 2005 Report Share Posted November 23, 2005 thanks for the most informative post. i hope to be joining you soon in my sundance optima or hot springs grandee. i expect to be wet testing over this holiday weekend. happy turkey day. m Quote Link to comment Share on other sites More sharing options...
greenhut Posted November 24, 2005 Author Report Share Posted November 24, 2005 We've been in the tub a frightening number of hours since it became usable last night Good thing we like the water relatively cool. When I said "98" to the installer he looked at me and said, "No, really?" We actually upped to 99 last night. Needless to say, we were not all that interested when the Caldera salesman said you could override the 104 max.. I'm happy just to not see puddles of leaked water seeping from underneath the tub when I open the basement door, so perhaps I am easily satisfied now, but we remain thrilled. We were somewhat poisoned against lounges from our prior Sundance because it just didnt sit right. In the Geneva, both my wife and I stay comfortably in place, and the foot jets are just awesome. We had previously dismissed lighting features as unimportant, but we really enjoy the "SpaGlo" system. Having the tub lit outside in the evening is a great safety/convenience. The part that surprised us was the cool ambience imparted by the in-tub lighting. When I purchased the tub, I purchased 8 additional Euro-pulse jets for $5 each. I started by putting them in the lounge foot jets. After trying it, I immediately swapped them back out. The stock Euro jet was better for foot massage. I think the pulse jets excel at more sensitive areas - like wrists and fingers. I wish the lounger had a wrist jet in the right arm-rest... I find it surprising that no manufacturer seems to pay much attention to hands. Back to the tub... jeff Quote Link to comment Share on other sites More sharing options...
Tyler Posted November 24, 2005 Report Share Posted November 24, 2005 Great post Greenhut. That's why everyone must wet test. The only think I can add is that perhaps your Hotspring salesperson didn't demo the Envoy correctly to you. Maybe they just left you alone in the spa room with no help. The diverter valves for the Envoy only have two positions, 3:00 and 9:00. When they are in the correct location they will lock into position. I think you might have run the diverter valves somewhere in-between. If you couldn't get the circular jets to operate correctly you definitely were not in the full position. I'm sure that's why the jets felt weak to you. Don't get me wrong, Caldera makes a fine spa, they are both made by Watkins, I just think your sales person wasn't very knowledgeable. Good luck with Spatopia. Quote Link to comment Share on other sites More sharing options...
greenhut Posted November 24, 2005 Author Report Share Posted November 24, 2005 Both diverters in the Envoy we tested had no stops - they moved a full 360 degrees. Either this tub was broken, this tub used an older design, or all Envoys behave this way. Tyler - Do you have an Envoy in which the diverters have stops? I'm certain that our operation of the diverters was not the source of our weak pressure assessment. In addition to being very "technical", we have owned a Sundance tub with diverter for > 10 years. Our issue with the diverters was understanding their positions and associated active jets. With some effort, we were able to isolate certain seats to maximize power with the diverters. We had no problem getting the circular jets to operate - we were unable though to get them to operate simultaneously with the foot jets across from them. Still, there may have been an issue with this Envoy if the diverters shouldnt be travelling a full 360 degrees... Quote Link to comment Share on other sites More sharing options...
Tyler Posted November 24, 2005 Report Share Posted November 24, 2005 The diverter valves can rotate 360° but they lock at 3:00 and 9:00. If they are out of those positions the jet pressure will be weak for each particular circuit. It's not a big deal. The important thing is that you found the spa for you. This is a good site also if you have any spa questions: http://www.whatsthebest-hottub.com/cgi-bin...oard=wtb-hottub Both diverters in the Envoy we tested had no stops - they moved a full 360 degrees. Either this tub was broken, this tub used an older design, or all Envoys behave this way. Tyler - Do you have an Envoy in which the diverters have stops? I'm certain that our operation of the diverters was not the source of our weak pressure assessment. In addition to being very "technical", we have owned a Sundance tub with diverter for > 10 years. Our issue with the diverters was understanding their positions and associated active jets. With some effort, we were able to isolate certain seats to maximize power with the diverters. We had no problem getting the circular jets to operate - we were unable though to get them to operate simultaneously with the foot jets across from them. Still, there may have been an issue with this Envoy if the diverters shouldnt be travelling a full 360 degrees... Quote Link to comment Share on other sites More sharing options...
