SteveCLT Posted June 15, 2020 Report Share Posted June 15, 2020 I have a 2006 Optima 880 spa and while the larger jets all work, the 5 1/8" silver rings that turn the jets have almost all come off. I believe that the problem is only the thin plastic that sits inside the ring to secure it to the jet. Is it possible to buy only those plastic inserts, or possibly just the ring with the plastic? The jets look like they cost about $40 each and there is really no need to replace the entire jet and I believe there are 9 of them. Thanks in advance Steve in Charlotte NC Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted June 15, 2020 Report Share Posted June 15, 2020 If you still have the rings just put them back on with a dab of silicone caulk the next time you are changing your water. I don't think they can be bought separately. They are called "jet escutcheon" if you want to try a google search. Quote Link to comment Share on other sites More sharing options...
