bigdshea2217 Posted June 2, 2020 Report Share Posted June 2, 2020 I have a 2009 J-480 with the old CD player/AM/FM and Ipod connection system. It's 2020 and I would like to replace it with something hot tub certified and bluetooth. I preferably like to find something with the same footprint as the unit I would replace. Any suggestions or aftermarket ideas? Thank you so much. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted June 3, 2020 Report Share Posted June 3, 2020 https://www.jacuzziofnorthcounty.com/bluewave-bluetooth-hot-tub-stereo/ Won't be cheap but should work as a retrofit for your Jacuzzi Not sure if it will retrofit for a 2009 but here is an example with price.. https://www.ebay.com/p/1943465359 Also if you go this route try pricing it through Sundance Spas might be a little cheaper than through Jacuzzi...same company but I like dealing with Sundance when I have to. I am sure there are other options out there as well Quote Link to comment Share on other sites More sharing options...
