Cusser Posted January 5, 2020 Report Share Posted January 5, 2020 OK, I have a 31-year-old CalSpa, in dusty Arizona. Over the years, I've tried different commercially-available "spa vacuums" which don't work well for dust, which seems to go through the filter element and settle on the bottom of the spa. The vacuum that uses a garden hose only works for bigger stuff, the fine dust goes through its vacuum sack. So I bought a 6-gallon Bauer wet-dry vacuum at Harbor Freight $45 with coupon), which has a firm extension and can reach the bottom of the spa, and tried this yesterday. Wow - it works way better than the old 2-gallon type I had been using which had a flexible, short hose, because now I can readily aim at the spot to be vacuumed, and can complete the vacuuming in one "sweep" without having to stop and empty the 2-gallon one. Highly recommend this !!! Quote Link to comment Share on other sites More sharing options...
Michael G Posted January 6, 2020 Report Share Posted January 6, 2020 Softub losing water is it evaporation Quote Link to comment Share on other sites More sharing options...
Jack hot tub help Posted January 10, 2020 Report Share Posted January 10, 2020 I would highly recommend the Paradise Spa Vac, they've been a godsend for us. Really easy to use and don't require any electrical feed or batteries, I'm unsure if they just run on pure magic, ha! Here's a link as to where you can get one: Paradise Spa Vac (although I don't know if they only ship to the UK) Another link which I found useful before purchasing my hot tub was this one: Hot Tub Buyers Guide Hope this helps Quote Link to comment Share on other sites More sharing options...
