hot spring spa leaking Jets ?
demj1308
Recently picked up a hot springs jetsetter model that is leaking, i noticed around the inside of the jet housings there appears to be a gasket with cracks. Is this housing removable without digging thru all the foam to get to back side ? or do i need to pull off side panel which is glued on and start digging ?
Thanks
The jet body is not removable without digging through the foam. You will more than likely have to cut the jet body in half with a wire saw from inside the spa as you won't be able to remove the nut from the back. Probably better off just trying to put a bead of silicone where the gasket is. May not hold, but it would be easier than cutting the whole thing out.
