The jet body is not removable without digging through the foam. You will more than likely have to cut the jet body in half with a wire saw from inside the spa as you won't be able to remove the nut from the back. Probably better off just trying to put a bead of silicone where the gasket is. May not hold, but it would be easier than cutting the whole thing out.
