When is it time to re-plaster?
On 11/13/2018 at 8:49 PM, Poolcovers said:
Pools should be re-plastered after every 10 years or when needed. This ensures that basin is smooth so that person who swims isn't injured by rough surfaces. Other than this there are other two signs that you can look for if your pool is in need of new plaster. Over time the plaster will wear away, leaving the concrete below exposed to water and chlorine.  Minerals like iron and copper, which can be found in your pool water, will often leave unsightly stains inside your pool over time. Unfortunately, these stains are often permanent and will require a new coat of plaster to cover up completely.
Thank you. Your answer is most informative.
