Hot Tub too hot
Ambient air temp and direct sun light can cause your water to heat without the heater. It's probably nothing but if you'd like to check it you'll need to drain off a little water and add fresh to bring the temp down below your set point, somewhere in the low 90's is good. Once the it's cooled, set your temp to 2 degrees above whatever the current reading is. If the unit runs the temp up to the set point and cuts out, no worries. If it keeps going past the set point by more than a degree then you may have an issue. Do it at night if you can when the temp outside is below what your water temp becomes once you cool it.
Like I said though, it's probably nothing. Good Luck.
