Hotsprings stuck on UT4 how to reset?
street
I need to know if it is possible to reset the control panel. The temp got set to the max ut4 which is 107 and is too hot. The down button for temp doesn't work at all, but all other buttons work. Aside from replacing the control head which is difficult to find the old one that goes with the IQ2000, I want to know if I can reset to the 102 factory setting? Unplugging just remembers the last set temp but there but be some way to clear the memory. Thanks!
No, there is no lock icon on. The down button just doesn't work and you would think they would make it so if you go all the way up, it would loop and start again on the low setting. Is there a battery on the board or something that can be pulled to remove the setting from memory? As I said, unplugging power isn't enough, unless there is a significant amount of time it needs to remain unplugged. Thanks
The temp down button on the front panel may not be pressing on the control panel button to make the temp go down.  The system has a memory to store the last temperature that was set.  You will need to contact a Hotspring dealer for service.
  • 10 months later...
@street where you able to resolve the UT4 issue. After a long period of not using (power switched off). I cleaned and refilled mine, put power back on and tried reducing temp by pressing minus button but no feedback, so I pressed pressed temp + and at ut-4 it stopped. Interface is not locked: so exactly as you explained. Any help appreciated. Service technician will be my last option. Many thanks
I jammed on the button hard enough and enough times that it eventually went down. Haven't touched it since. If it get touched by the kids or anyone else, I fear, I am done. I'd love to find a solution. Seems a reset should be possible. Of course nobody from Hotspring would look at these forums. If you find out, post the solution. Good luck
