DavidL
Hot Springs Jetsetter no power
My Jetsetter ix a 2003 model with IQ2020 CONTROL PANEL. Spa was wirking perfectly , but i decided to do a water change and cleaning. I disconnected the power cord and proceeded with the draining. After i refilled it , i plugged it in, the gfci is reset but no power light on the spa and nothing works. I pulled the panel cover, and checked the power at the connections an if showed 122  v. What else might need reset, or replaced?
Share this post
Link to post
I would look on the back of your control panel for any obvious burn marks on the board (black).  I would check fuses to verify they are ok, also check for bad solder joints etc.  If you have already done all that someone more knowledgeable than myself about the spa would have to chime in.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
