How To Repair Or Replace Hot Tub Light/housing
saxman
hi I have a 14 year old beachcomber 550x - the underwater light no longer works. I drained the tub and when removing the lens cap, found that the housing unit threads to hold the cap in place are no more (cap threads are fine) . It is also possible that the housing may have been leaking due to the thread issue, as I had a leak as well. I believe its a standard 3 1/2 or 2 1/2 housing with a 12 volt bulb driven by the balboa pack.
what are my options here? - are there any diy steps to replacing the housing - I understand I may need to get to it from underneath, but not sure....or is it possible to silicone the cap back in and eliminate any potential for leaks? thanks
