lurky Posted August 16, 2015 Report Share Posted August 16, 2015 Hi I was refilling my hotspot mallorca with the hose and it fell out of the tub and onto the ground where it was in a position to shoot into the open cabinet onto the motor. This went on for some time. Should it still operate when it dries? How long before I turn the power back on 24 hrs? 48? Thanks Quote Link to comment Share on other sites More sharing options...
Hot Spring Official Posted August 21, 2015 Report Share Posted August 21, 2015 Hi, If, you suspect that there is water in your elect motor, that could be an unsafe situation. You would want a professional to address it as there is some potential for electrical hazard, to you and the spa. If you feel comfortable enough powering it up, after having a few days to dry out, feel free to do so. If the motor is in working order you will notice it right away. However, if it is not please contact your local spa tech for assistance. Hot Spring Customer Service Quote Link to comment Share on other sites More sharing options...
