KrisH71 Posted July 11, 2015 Report Share Posted July 11, 2015 Hey folks, I'm somewhat new to pool ownership and maintenance so bear with me and while I do have a pool guy, he is very slow to get back to me and very quick to overcharge on things (tried charging me $115 to replace a $12 foot on my pool vacuum) so I'm considering tackling this issue myself. I noticed the other day that I had a small leak from the upper pipe on my pool filter had a leak which was causing the pool to not run properly (I have a waterfall that flows from the hot tub into the pool when the pool is running and it was not running properly despite the water levels being good). I turned the pool off for the time being but when I revisited it to take a picture of the leak for reference for the pool guy, the fitting popped and water sprayed everywhere. Essentially, the coupling (the spinning piece that joins the pipes) blew off and a rubber o-ring was left hanging around the male threaded pipe coming off of the filter. I'm hoping this is as simple as putting the o-ring back where it goes and tightening the coupling. I've attached some pictures to hopefully illustrate my issue. Before I go out and waste more water, I thought I would run this by you all and get some advice. Thanks in advance for any help you can offer!Kris Quote Link to comment Share on other sites More sharing options...
nmcd1012 Posted July 12, 2015 Report Share Posted July 12, 2015 I would give the o-ring a shot. The water spraying back towards the pipe (first photo) makes me think it should be a very simple fix. Quote Link to comment Share on other sites More sharing options...
ronnyaderson Posted July 29, 2015 Report Share Posted July 29, 2015 If you are still facing this problem then here is your solution. I hope you get rid of your leak http://blog.poolfilters.biz/a-guide-to-repairing-leaks-in-pool-pumps/ Best of luck Quote Link to comment Share on other sites More sharing options...
