SpaInAz Posted April 17, 2015 Report Share Posted April 17, 2015 New to the forum and new to owning a tub. My wife and I just picked up an Amore Bay from D1. We shopped around and we decided on the Bay based on the shape and features. That being said, we are all filled up and starting. But I had a question. What filter does the Vision Cateridge go in? Or does it matter. The skimmer or the circulation filter? Also when adding chemicals should I toss into the middle or add into the same filter? Thanks! Quote Link to comment Share on other sites More sharing options...
d1dennis2009 Posted April 17, 2015 Report Share Posted April 17, 2015 you place the vision in the filter with the ultrapure lid (Not the skimmer) and you should add chemicals to the center of the spa while the pumps are running. Also, allow the pumps to run with the cover open for 30 minutes after treating the water. Quote Link to comment Share on other sites More sharing options...
SpaInAz Posted April 17, 2015 Author Report Share Posted April 17, 2015 Awesome!! Thank you d1dennis! So far we are loving the tub. Took a few hours to get to temp and so today is the first time we are going to use it. One last question, is it normal for some air to be coming out of the circ pump? It kind of spits from time to time. Seems to have a good amount of ozone bubbles. Quote Link to comment Share on other sites More sharing options...
SpaInAz Posted April 18, 2015 Author Report Share Posted April 18, 2015 Okay so now I have one more question. There is a slight water mark line. Kind of brown or yellow. Really faint. What could this be?? The water Chem is perfect and everything seems normal. Quote Link to comment Share on other sites More sharing options...
Dr. Spa Posted April 18, 2015 Report Share Posted April 18, 2015 Sounds like gunk....a technical term. Quote Link to comment Share on other sites More sharing options...
SpaInAz Posted April 18, 2015 Author Report Share Posted April 18, 2015 Gunk? Quote Link to comment Share on other sites More sharing options...
Dr. Spa Posted April 18, 2015 Report Share Posted April 18, 2015 Gunk, crap, stuff. One more thing, you say "The water Chem is perfect". But what YOU consider perfect, and what the experts here consider perfect, quite possibly are two different things. What are the exact readings, and how are you determining this....well water or city water. Quote Link to comment Share on other sites More sharing options...
SpaInAz Posted April 18, 2015 Author Report Share Posted April 18, 2015 Yeah after I wrote that I realized that could be interpreted like I knew all. This was on first fill, city water. Chlorine, PH, Alk are all spot on according to test strips. If there is something else I should be doing please let me know. Quote Link to comment Share on other sites More sharing options...
SpaSage Posted May 2, 2015 Report Share Posted May 2, 2015 Did you add clarifier? If you add clarifier and the water balance is off, especially the PH, clarifier can clump things together too quickly. When this happens all of that stuff that got clumped together floats to the surface and sticks to the water line. Dealers will often tell you to add clarifier weekly. You don't need to do this. If the water is balanced correctly it should be clear without adding clarifier. I suggest you either reduce or eliminate the use of your clarifier for the next couple of weeks. Quote Link to comment Share on other sites More sharing options...
