polar175 Posted March 22, 2014 Report Share Posted March 22, 2014 I have a Dream Maker x500 spa. I have power to the top side control panel but when I push the button to activate the pumps it clicks once. I checked the fuses in the balboa control panel and they don't appear to be blown (I counted 3, 2 clear fuses and 1 white fuse). I checked the wire from the panel to the pump with a voltage tester and there is no power to the pump. please help!! Quote Link to comment Share on other sites More sharing options...
ChaiSTi Posted March 23, 2014 Report Share Posted March 23, 2014 You might want to double check that white fuse. That white fuse can't be visually inspected for good or bad. You have to either test for voltage on booth side or pull it out and test it for continuity. Quote Link to comment Share on other sites More sharing options...
