nogbody Posted September 30, 2013 Report Share Posted September 30, 2013 Hey y'all first time poster here.I have Morgan Spa (not sure the model, but it's probably from early-mid 2000's. (Maybe a Morgan II Deluxe Digital Dual Pump) Everytime theres a power failure the spa comes back on, the display is blinking and the temperature is set to some ungodly hot degree like 190... And the spa tries to heat up to get there!!! I usually find it then at an actual temperature of 116-120 and I freak out. If I lower the temperature down it turns off, and of course once I pass 104 on the way down it won't let me increase it past 104. Plus the display is blinking but I think it does that after a power outage by design.Do any of you know why it would be doing this? Is this a electronic failure? Do i have a setting off? I've checked the manual that I found on line, but there's no metion of setting like this. It just seems so weird that it would set it self to such a high temperature, and it only happens after a power outage.Thanks for any input before I have to call a repair man (i'm pretty handy and would like to do it myself if possible.) Quote Link to comment Share on other sites More sharing options...
Leeboy Posted February 4, 2014 Report Share Posted February 4, 2014 Did you ever figure this out? Mine was going into over heat, and it was because my jets were all closed and it wasn't getting the circulation during filter or cycle mode Quote Link to comment Share on other sites More sharing options...
