Hot Tub Motor/pump Seized
Charingx1
I have tried to start my hot tub after a year of not using it. The motor runs then stops after 5/6 seconds. I have taken it apart and one of the bearings is seized. USing pliers etc i managed to get it turning but plugged it in again and the result was the same, runs briefly then trips out.
The model is a century pool and spa motor a.o.smith. HP 1.5 220-240v. The problem I am having is that I can't get this motor in the uk. Can anyone help at all with what on earth I can replace it with. It is single speed and the connector is 2x2 inches. Il try post a picture if I can.
Any help would be massively appreciated as I have no idea what to do!
Many thanks
Hayley
For anyone reading this, the OP is in the UK. Their electricity there is DIFFERENT than in the states as it's 50 hz, and in the states it's 60 hz. A motor intended for the states (60 hz.) will run at a lower speed and overheat running on 50 hz.
