Mcblock Posted August 10, 2013 Report Share Posted August 10, 2013 I recently purchased a hot springs sovereign circa 1995 and the heater has stopped heating. It is the 115v model and I have removed the filters as well as checked the high limit switch. There are two thermocouples and only one is inserted into the access hole on the spa pack side of the and the other is just laying in the spa pack area. There is a small leak from the hole where the one thermocouple is inserted. Any suggestions to the heating problem as well as thermocouples and the leak. Thanks Quote Link to comment Share on other sites More sharing options...
Hot Spring Official Posted August 12, 2013 Report Share Posted August 12, 2013 Hi Mcblock, Thanks for posting; I can help you with this. Can you provide the serial# to your spa? Thanks, Steve ---Hot Spring Spas--- Quote Link to comment Share on other sites More sharing options...
