jpeck1981 Posted November 20, 2012 Report Share Posted November 20, 2012 I noticed a slow leak in the corner of the hot tub by the corner seat with the precision jets. I am assuming the leak is due to the jets in that seat. My question is more based on how do I take off the corner panel to the hot tub. I removed the side panel expecting the other panel next to it to be able to be removed but that was not the case. Do I need to just pry off the three vertical side panels and replace them or nail them back on when I'm done. I am assuming the leak is from an elbow joint or connection or something of this nature in that corner. It is very slow (about a drip per second) and haven't even been able to notice it by water level yet. I just recently got the hot tub for free and it has worked fine up until this point so I would like to fix it quickly. Thanks for any help. Quote Link to comment Share on other sites More sharing options...
Hot Spring Ace Posted November 20, 2012 Report Share Posted November 20, 2012 Yes, just pry them off carefully and you'll be able to reuse them. Quote Link to comment Share on other sites More sharing options...
