migfran Posted August 14, 2012 Report Share Posted August 14, 2012 Hello,thanks for the help to start off. Just moved in to a home and have this spa in my backyard. I have tried all modes,std,ecn and SLP. Filtration will not stop after 4-5 hours. I have the manual and it says once turned on from circuit breaker it takes 2 hours to filter. Anyone else have this problem or have any suggest. Thank you very much guys! Quote Link to comment Share on other sites More sharing options...
PreservedSwine Posted August 14, 2012 Report Share Posted August 14, 2012 It could be a few different things. SLP, ECN, and Std are modes of operation, but there are also separate programmable filtration cycles, f2, f4, f6, f8, fc. If you're in anything other than f-2, it will run longer (f4 will be 4 hours every 12 hours, f6 six hours every 12, etc) To access filtration cycles, try pressing a temp button, followed by a jet pump button. Additionally, if the spa has yet to reach the set temp- it will continue to run until it reaches the desired temp. Quote Link to comment Share on other sites More sharing options...
