huey graphite Posted June 24, 2012 Report Share Posted June 24, 2012 I purchased an Infinity hot tub 5 years ago. It has a Balboa Instruments control board #54585. For about a year now it has been overheating. Will heat to anywhere from 105 to 109 regardless to what temp I have it set to. I tried swapping both of the sensors but the 2 sensors I installed were questionable (came from a used control unit). No change in symptoms. Then about a month ago my GFCI started to trip intermittently. I removed 1 of the 2 legs that provides power from the circuit board to the heater. The connections are flat copper bands that are labelled HT1 &HT2. This SHOULD prevent the heater from turning on. Now....the GFCI no longer trips...but the heater is still coming on. How is this possible?????? Any advice is greatly appreciated. Quote Link to comment Share on other sites More sharing options...
tony357 Posted June 24, 2012 Report Share Posted June 24, 2012 not quite sure of your wiring for that heater, but you could be running it on 110 with one leg disconnected.. Quote Link to comment Share on other sites More sharing options...
Chas Posted June 24, 2012 Report Share Posted June 24, 2012 You are heating with the pump. Cut WAY down on how much it runs, and your problem should go away. At least, the problem with the spa. Your other problems may not be as easy. HTH Quote Link to comment Share on other sites More sharing options...
n1oty Posted June 25, 2012 Report Share Posted June 25, 2012 First, it is very dangerous to continue to power a suspected ground faulted heater with even just one cold pin connected to power. Disconnect both heater connections first. If the tub continues to overheat as Chas mentioned, you have excessive filtration time and it must be hot in your area. If the overheating issue goes away, it means that the ground faulted heater was powered at 120 volts by completing a circuit through ground, an incredibly dangerous scenario. Replace the heater and your GFCI in that case. John Quote Link to comment Share on other sites More sharing options...
