remove the hose from the control panel have someone push the switch as you feel for air pressure, it is a light amount of air maybe a couple inch pounds..
Also you can check the switch for an air leak, if you depress the switch and hold your finger over the end of the hose it should stay depressed, if the button works its way back up you have a leak in either the hose or switch.
here is a pic of air switch.
