roscoepm Posted December 15, 2011 Report Share Posted December 15, 2011 Hi, I'm new to ths hot tube world and needed a little help. I bought a used Dream maker X-cal that was in great shape. The problem that I'm having is that when the 100 degree is reached on start up I can't get it to go past that. It will go down in temp fine. Should I replace the button panel? Thanks Quote Link to comment Share on other sites More sharing options...
Mark SC Posted December 16, 2011 Report Share Posted December 16, 2011 Yes, most likely a top side panel issue. They are simple to replace. Just make sure to match it to your control pack. Dreammaker went from Balboa, to CE, and back to Balboa. If you have an aluminum box, it should be Balboa. A blue box is CE. My CE topside and control pack both failed this year, so I replaced with Balboa--no problems since. Quote Link to comment Share on other sites More sharing options...
