Caldera Kauai owner Posted September 12, 2011 Report Share Posted September 12, 2011 I have an older 2006 Kauai Caldera Paradise Series tub. Recently after I cleaned and filled the tub, upon the tub heating to the proper temp, I tried to run the tub. The jets and the LED lights do not come on. The tub's cleaning cycle comes on. When the cleaning cycle is on, the jet pump seems to be working fine. Does this sound like a mother board issue or a switch issue? Is there a pressure switch that may have gone bad on the jet pump? If so, then why wouldn't the spa LED's not come on? Quote Link to comment Share on other sites More sharing options...
Spa_Guru Posted September 24, 2011 Report Share Posted September 24, 2011 A lot of the Calderas in those years had cuircuit board issues, and this sounds like one of those, the pressure switch is activated by the pump, not vis versa, so that is not the problem. Quote Link to comment Share on other sites More sharing options...
