dmfoss Posted January 30, 2007 Report Share Posted January 30, 2007 Hello, New member, first post. I have a 2000 model Ottawa spa by Great Lakes Spa. The spa came with the house and was in a state of disrepair when I moved in last month. The spa is mostly fixed now but there is still a problem with the pump operation. When the spa is inactive for a few hours the pump will not operate in low speed. This prevents the automatic filter cycle from starting, and also prevents the spa from maintaining the proper temperature. I can termporarily alleviate the problem by pushing the JET button which starts the pump in high speed. This initially works to turn the pump on in high speed or turn the pump off. However, after the pump has run in high speed for about ten minutes, both pump speeds work properly again. Everything works fine until the pump turns off for a while or after the next filter cycle and the pump is inactive for an hour or so. I don't know if it this is a pump motor problem or a circuit card problem (Balboa instruments 410E or 411E control system). It seems to me that if the card was bad, the low speed wouldn't work at all. Maybe the pump motor is failing and must 'warm up' by running in high speed for some time before the low speed will work again. Any advice would be greatly appreciated. Thanks, Don Quote Link to comment Share on other sites More sharing options...
Chas Posted January 30, 2007 Report Share Posted January 30, 2007 Any advice would be greatly appreciated. Thanks, Don Welcome, Don. I would start by finding out if their is power to the pump or not. You will have to allow it to sit, and then meter the pump to find out if the contol system is sending it power and it is not running, or if the control system is not sending it power at all. Good place to start. Quote Link to comment Share on other sites More sharing options...
dmfoss Posted January 30, 2007 Author Report Share Posted January 30, 2007 Thanks, I'll try it. Don Quote Link to comment Share on other sites More sharing options...
