bekahandco Posted April 26, 2011 Report Share Posted April 26, 2011 I just purchased an Ecco brand Hot tub model L580. Due to overhead clearance issues I have to purchase a new cover. Th specs for the tub are 92x92x39. I am looking for a trifold cover, with the folds being 23",23" and 46". Any suggestions on where to get a cover this size? Desparately hoping that someone can help! Quote Link to comment Share on other sites More sharing options...
THE SPA GUY Posted April 26, 2011 Report Share Posted April 26, 2011 depending on were you are located , if you have a local hot tub cover company they can make it. otherwise your local spa dealer should have a place were they order covers from and should be able to get no problem.. Quote Link to comment Share on other sites More sharing options...
BeyondNice Posted April 27, 2011 Report Share Posted April 27, 2011 BE CAREFUL! The specs you list for your tub, 92x92x39 is likely the length x width x height. When ordering a hot tub cover, you will need to specify the corner radius, assuming your tub has rounded corners. When you do so, be sure not to confuse the 39" dimension with the corner radius dimension or you will wind up with a cover that will not fit! You should be able to order a three panel cover from anywhere. You should expect the price to be higher than a two panel cover, because 50% more raw material will be used to make the three panels. You may be able to mitigate this, if a dealer will work with you, as the foam comes in 96" X 48" sheets. One of those COULD be used to make BOTH 23" panels. Also, be thinking about how you want the three panels attached, if at all. I recommend attaching the 46 to the 23 with a standard cover hinge, and have the remaining 23" panel separate. Some manufacturers can make a three panel cover so it will fold up like the letter Z, but this may not work due to your overhead limits. Hope this helps! Quote Link to comment Share on other sites More sharing options...
