Rick D Posted March 3, 2011 Report Share Posted March 3, 2011 Hi, I have a Downeast Spa with a Balboa MS510S controller installed. It is a 3 Pump system, pump 1 is working on low speed, pumps 2 and 3 are fine. When pump 1 is running at low speed, the LED next to the pump 1 button is lit. If I press the pump 1 button to go to high speed, nothing happens. The LED stays lit, the pump does not go into high speed, no clicking in the control box as when turning other pumps on. Any ideas? Thanks, Rick Quote Link to comment Share on other sites More sharing options...
ChaiSTi Posted March 9, 2011 Report Share Posted March 9, 2011 Are you able to activate the low speed when it's not running? If not, maybe there's a problem with that jet button. Quote Link to comment Share on other sites More sharing options...
