Gouie Posted February 2, 2011 Report Share Posted February 2, 2011 Calling all experts out there, I've got an issue. Temps here in western Canada have been very cold over the last few days. The tub has been great with zero problems, until today. Went out to take a chemical reading and I've got an "IC" error on the panel (panel is a Balboa 500Z series, tub is an Infinity Spa). What doesn't make sense is the water is still relatively warm. My interpretation of the error is that a potential ice condition exists but the heater etc should operate as normal until the condition is rectified. I cannot get the tub to operate which has me very concerned about frozen/broken pipes. I've power cycled the unit but the IC condition re-appears during the prime process (priming never begins). Any advice or direction would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Gouie Posted February 3, 2011 Author Report Share Posted February 3, 2011 Just thought I'd follow-up. Turns out the pump fuse was gone. Boy am I glad I caught it when I did. After replacing the fuse and cycling the power a couple of times the water temp read 40 degrees. We've had some wickedly cold weather over the last couple of weeks but it broke the same night I suspect the fuse popped. Not the easiest fuse to find by the way, I've stocked up. Can anyone recommend a remote floating thermometer? Quote Link to comment Share on other sites More sharing options...
Hillbilly Hot Tub Posted February 3, 2011 Report Share Posted February 3, 2011 any pool store will have a floating thermometer, you can also get ones that you can read from the house. the ones we carry are made by nu-temp, they also have an alarm on them. i have included a link. there are several different kinds http://www.nu-temp.com/600.htm Quote Link to comment Share on other sites More sharing options...
