SessionDrummer Posted June 29, 2010 Report Share Posted June 29, 2010 Hello, have what should be a simple question regarding our Hayward Pro 1.5 HP pump leaking from the basket cover when turned off. We typically run the pump 24/7 for our EW Millenium 15x30, no leaks, works great. When we shut it off to clean the pool, or empty the pump strainer basket, water leaks out (only when pump turned off) from the basket. When I say basket I mean the round portion that has the strainer with a circular cover with o-ring. The previous pump was replaced due to a bad bearing, and this one is new, with a new o-ring. I can prevent it from leaking (when turned off) by almost overtightening the basket lid, but my fiancee cannot open it to empty the strainer. Great pump, but with the economy as it is, and the probable installation of a timer, we can't have water leaking out when it's on it's off cycle. I haven't really lubricated the o-ring (thought I read that somewhere), and all I can guess is it's gravity feeding down from the pool out the basket lid. Only happens when it's turned off, and no air is leaking into pump when running. Can I stack a second o-ring on top of first for a tighter seal ? Quote Link to comment Share on other sites More sharing options...
polyvue Posted June 30, 2010 Report Share Posted June 30, 2010 Hello, have what should be a simple question regarding our Hayward Pro 1.5 HP pump leaking from the basket cover when turned off. We typically run the pump 24/7 for our EW Millenium 15x30, no leaks, works great. When we shut it off to clean the pool, or empty the pump strainer basket, water leaks out (only when pump turned off) from the basket. When I say basket I mean the round portion that has the strainer with a circular cover with o-ring. The previous pump was replaced due to a bad bearing, and this one is new, with a new o-ring. I can prevent it from leaking (when turned off) by almost overtightening the basket lid, but my fiancee cannot open it to empty the strainer. Great pump, but with the economy as it is, and the probable installation of a timer, we can't have water leaking out when it's on it's off cycle. I haven't really lubricated the o-ring (thought I read that somewhere), and all I can guess is it's gravity feeding down from the pool out the basket lid. Only happens when it's turned off, and no air is leaking into pump when running. Can I stack a second o-ring on top of first for a tighter seal ? Can't address the idea of placing a second o-ring (this doesn't sound like a good idea) ... but you should try a bead of Jack's Forumula 327 or other brand (or generic) pool lube around the threads and existing o-ring. That way, tightening and loosening the pump pot cover should be a lot easier and the lube should protect the o-ring as well as provide a water tight fit. Quote Link to comment Share on other sites More sharing options...
britinusa Posted July 1, 2010 Report Share Posted July 1, 2010 Lubricating it is the best thing to do, If you dont you run the risk of breaking the O ring (I did that) Quote Link to comment Share on other sites More sharing options...
mn pool and spa Posted July 2, 2010 Report Share Posted July 2, 2010 Is it a constant leak if it is i would go pick up a new oring that should solve the problem. If it just spits a little water out when u shut it of it is beaing caused by back pressure in your sytem which isnt a big deal. Another option is tighting it down tighter and come up with a tool ure fiance can use to get more leverage on the pumplid. Quote Link to comment Share on other sites More sharing options...
Akes Posted July 24, 2010 Report Share Posted July 24, 2010 SessionDrummer, Have you found a solution to your leaking Hayward basket strainer problem? Mine has started leaking in the same manner. I just replaced the O ring but did not help. Any learnings you can pass along? Thanks! Quote Link to comment Share on other sites More sharing options...
Smaller IS better Posted July 25, 2010 Report Share Posted July 25, 2010 "A leak will only leak if it is below the water line." A novel "solution" would be to raise the Pump to the water level of the Pool. That will reduce the pressure on the seal and reduce any leak to a very small trickle (if any.) Do not locate the pump ABOVE the water level or the leak may work in reverse and allow air to get into the pump and the water to drain back into the pool causing the pump to lose it's "prime". Quote Link to comment Share on other sites More sharing options...
